After i installed version 2.35 , ftp webupload cannot be selected anymore.
it jumps to SFTP ??? Why , my webhost doesnt support SFTP
is there a workarround ?
FTP does not work anymore ? only sftp ??? why ???
Hans ON3MOH onbota supervisor
Re: FTP does not work anymore ? only sftp ??? why ???
Hans,ON3MOH wrote: 15 Feb 2025, 13:23 Hello
I don't use that option, but have you looked in the Settings/Configuration/Web Integration ??
Maybe the FTP upload option got mal-adjusted with the update.
- web-upload-config.png (66.84 KiB) Viewed 8582 times
Greetings.
I concur with Hans ON3MOH observation.
SFTP once selected can't be reverted back to FTP!
Program somehow disregards reverse setup.
I installed 2.34 release...
Yep indeed , when you click on FTP , it goes back to sftp for no reason. Hope they can fix this problem asap. I did go back to 2.34 ,
"But it surely can't be the intention of an update to introduce a limitation instead of an upgrade. I hope this gets adjusted as soon as possible."
undocumented new featureON3MOH wrote: 15 Feb 2025, 17:39 "But it surely can't be the intention of an update to introduce a limitation instead of an upgrade. I hope this gets adjusted as soon as possible."
I'll check and fix asap. Sorry for the unnoticed issue.
Lele IW3HMH
Lele IW3HMH
Thx , hope this Will Be fixed Very soon. Kind regards from Belgium. Can you keep me up to date please. My email [email protected]
Best regards,
Hans
ON3MOH
Best regards,
Hans
ON3MOH
New version is available here: https://www.log4om.com/l4ong/release/Lo ... 35_1_0.zip
will be published soon.
PLEASE report for issues and if problem is fixed.
Hello Daniele.
Previously reported issue is successfully resolved - thank you!
