Recording of Grid Squares
Posted: 16 Feb 2025, 01:50
by VK7XX
If this is available, I have missed it and cannot find it....
Is there any way to have Log4Om record a 6 character Grid Square instead of the current 4 characters ??????? and, if it is not available, could it be added, probably as a setting ???
Regards
John
VK7XX
Re: Recording of Grid Squares
Posted: 16 Feb 2025, 08:58
Choice is in program config
Posted: 19 Feb 2025, 02:35
by VK7XX
G4POP wrote: 16 Feb 2025, 08:58 Choice is in program config
thanks mate, I think I might need glasses, damned if I can find it, but I'll keep looking..
Posted: 19 Feb 2025, 02:41
by VK7XX
Is this the setting in "User Preferences" ??? If yes, Mine is set to 6 but it only saves 4 :-(
Posted: 19 Feb 2025, 10:22
I guess that the QSO's are from FT8 which usually only send 4 digits, QSO's saved in Log4OM directly will be 6
Providing your using the UDP connection to WSJT in Log4OM you can edit the connection to 'Update the grid' when adding it to the logbook
Posted: 20 Feb 2025, 04:53
by VK7XX
G4POP wrote: 19 Feb 2025, 10:22 I guess that the QSO's are from FT8 which usually only send 4 digits, QSO's saved in Log4OM directly will be 6
thanks heaps Terry, that explains it all... yes, 99% via Digi FT8 or FT4.
cheers from way down under de John
VK7XX
Posted: 20 Mar 2025, 05:11
by bh2rmx
I have the same problem. I have set all the settings I could find and the situation has not changed. Should I wait for the next update?
