Hi, I started logging my QSOs using SQLite, but now considering switching to MariaDB, so I can access my data
a from different computers.
Is it as simple as exporting all logged QSOs to ADIF files, connecting to MariaDB and importing saved ADIFs into new database?
Configuration is not dependent on database? shall I just copy AppData/Roaming/Log4OM directory?
Migration from SQLite to MariaDB
73 Mike SP5MTD
Re: Migration from SQLite to MariaDB
Why bother?
I have been accessing a common SQLITE database for 10 years from 3 PC's using Google Drive or Dropbox
Why not check the user manual and this forum by searching on word 'Dropbox'
Unless your running several contest stations at the same time or have over 120K QSO's MySql is not needed
I do not like to use cloud services, I have good backup for my self-hosted MariaDB and also my own VPN access. I consider such a setup independent and more future proof.
73 Mike SP5MTD
I know
. So any idea if exporting / importing logged QSOs as ADIFs is the way to go? Will I get full data into new DB?
73 Mike SP5MTD
Just follow the instructions in the user guideSP5MTD wrote: 19 Feb 2025, 18:02 I know. So any idea if exporting / importing logged QSOs as ADIFs is the way to go? Will I get full data into new DB?
There is no instruction in the user guide for database migrations, a least I didn’t find any. My gut feeling is that ADIF export / import should to the job. The only doubt is if I cover all data that way.
73 Mike SP5MTD
