Winkeyer with RemoteTx Connect
hb9cat
Post by hb9cat »
Hi all,
Log4OM works fine with my loical winkeyer, no complains at all about that
I am also accessing a remote station using the RemoteTx software, they also provide a "RemoteTx Connect" software that actually emulates a winkeyer locally, then sends CW to the remote transceiver. (A bit like Flexradio is doing with SmartCAT).
That winkeyer works fine with N1MM; as I try to access it with Log4OM I get this message from Log4OM:
"WK Echo test failed! Reset unit"
So my question is: is the Echo test mandatory or could it be turned off ?
Best 73s
Marco HB9CAT
