Date Range in QSO Manager not sticky
M0RWX
Post by M0RWX »
In the QSO Manager, when filtering for a single day, I select the same date for the QSO Date Rage 'From' and 'To' fields.
When I then perform an action on a selected number of rows, (e.g. single field update) the rows that are returned after the action has finished fall outside the date range, whilst both radio buttons for 'From' and 'To' remain 'on' in the display.
I then need to toggle one of the from/to radio buttons off/on, for the rows to return again the QSOs as per selection criteria (the single day).
The same happens when in the QSO Manager, you want to combine a QSO Date Range with a filter. Having selected the date range first, then when executing the criteria in the filter, the date range is no longer applied, whilst the radio buttons remain ticked. An off/on toggel of the To Date then restores the date range.
Version 2.35.1.0
