Force Quite to exit
N1FST
Force Quite to exit
Post by N1FST »
Recently I have had a problem with trying to exit log4om. When I close the application it starts to close down and just hangs with the closing screen and I need ot force quit it.
See pic 1.
When I try to restart it it states there are UDP ports open. I run WSJtx and grid tracker every now and then to do ft8.
Radio is a dx10 and running onmirig for cat control
Re: Force Quite to exit
Tim,
Why don't your first shut down all the 3rd party programs that run the FTxx stuff? Then attempt a closure of Log4OM V2.
As another method of trouble-shooting run Log4OM V2 by itself. Do NOT have any of the FTxx APPs running at all in the background, etc..
Just your rig and Log4OM V2.
How does it start up and close down in that circumstance?
I would suggest there is a setting in one of the 3rd party APPs that is keeping a port active/alive, but you have to peel away the layers of the onion to figure out where it is.
