I was using LOG4OM2 in Contest Mode during the last weekend's CQ-WPX-SBB contest and the CAT control (OmniRig) kept being knocked offline.
After about 5 times in 60 minutes, I started troubleshooting:
- I changed the USB cable, the old had one choke on the computer end, the new one had chokes on both ends
- I checked the CAT control and radio settings and the were the same: RIG1: IC-7300, COM3, baud rate 19200, bits 8, none, stop 1, RTS High, DTR High, Poll 500 ms, Timeout 4000ms, RIG2 None
- I looked in the log (didn't save it)
and it said "[OmnirigEngine] CAT Control False, Radio Timeout" or something similar
- I turned off VOCAP service
- I run with the x4 cluster views detached showing the 10m 15m 20m and 40m bands ("Menu>view>View cluster" to create the detached view)
- I also noticed that these views were throttling as expected due to the contest but I've seen that before
Seems like some kind of latency issue between the prg and the radio.
Here is the ASK:
What settings should I change to prevent this? Any help is appreciated!
BTW: I think LOG4OM2 is a great program and I don't mind using it in the Contest Mode as I am a casual contester only looking to pick up needed callsigns, I do upload my contest logs
