Losing CAT FT101MP
M0TDW
Losing CAT FT101MP
Post by M0TDW »
Been running LOG4OM for a number years on various rigs without any issues.
Connected a Yaesu FT101MP and I am experiencing loss of CAT control.
Yaesu drivers installed prior to connecting the radio.
It isn't rf, it happens when I haven't been transmitting.
I have checked the usb ports don't switch off to save power.
I am running LOG4OM and Omnirig as administrator.
In Omnirig I have tried selecting the rug as FT101D and FT991.
I have tried changing the CAT speed from 38400 to 19200.
As a precaution I changed the USB cable reinstalled Omnirig.
USB ports don't switch off to save power.
Omnirig settings as follows:
Rigtype FT101D
Baud Rate 38400
Data Bits 8, Parity None, Stop Bits 2
RTS Handshake DTR Low
Poll int 100 Timeout 4000
Windows 11 Home 64 Bit v24H2 OS Build 26100.3476
Be grateful for any advice,
Bill
M0TDW
Re: Losing CAT FT101MP
Loss of cat completely, like it never connects or intermitently if left in RX idle?
Log4OM version number please
M0TDW
Post by M0TDW »
LOG4OM version 2.35.1.0
It will disconnect at different intervals sometimes 5 mins or 10mins. Just says it is offline. I can Start CAT again and it will connect but not stay connected for long.
I don't have anyother radio related software running at the same time.
Bill
Have you engaged trace mode in the help menu and then read the log file after the next disconnect?
M0TDW
Post by M0TDW »
Not sure how much info you need from the file.
I lost at 11.59
Bill
2025-04-07 11:59:30.0551 TRACE: [FwHam][ExtractCallsign] : BH8ESR -> BH8ESR with prefix
2025-04-07 11:59:31.5281 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Executing planned scheduler...
2025-04-07 11:59:31.5291 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2025-04-07 11:59:31.5291 TRACE: [LogWriter][DumpProcess] : ## DUMP ##GetLog DbSqlite 1
2025-04-07 11:59:31.5291 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext dje_z3AL94SJ5BUMAZST9U72UYLLP26TQSCGYCW_ejd 1
2025-04-07 11:59:31.5291 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Planned scheduler executed...
2025-04-07 11:59:33.9795 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2025-04-07 11:59:33.9835 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2025-04-07 11:59:33.9835 TRACE: [CatManagementHub][dje_zHZ7N4E5AKNWCW4SURNSCFW3AP36Q_ejd] : CAT CONNECTED: True Timeout: False
2025-04-07 11:59:33.9845 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: True
2025-04-07 11:59:33.9907 DEBUG: [OmnirigEngine][GetFrequency] : CAT OMNIRIG2 -> LOG4OM RIG 1 VFO: PM_VFOAA Freq: 14009970 RX: 14009970 TX: 14009970 FreqA: 14009970 FreqB: 7013100 SPLIT: PM_SPLITOFF
2025-04-07 11:59:33.9927 TRACE: [OmnirigEngine][GetFrequency] : CAT PACKET: Omnirig Rig1 EMISSION:Undefined MODULATION: Undefined OnAir:False Split:False
VfoA Freq:14009.97 Tx:True Rx:True Valid:True
VfoB Freq:7013.1 Tx:False Rx:False Valid:True
2025-04-07 11:59:36.0850 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from G5RPM
2025-04-07 11:59:36.0885 TRACE: [FwHam][ExtractCallsign] : G5RPM -> G5RPM with prefix
2025-04-07 11:59:36.1563 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from PA3ARP
2025-04-07 11:59:36.1574 TRACE: [FwHam][ExtractCallsign] : PA3ARP -> PA3ARP with prefix
2025-04-07 11:59:36.2392 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from JH5WVY
2025-04-07 11:59:36.2392 TRACE: [FwHam][ExtractCallsign] : JH5WVY -> JH5WVY with prefix
2025-04-07 11:59:36.3188 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from IU1QYV
2025-04-07 11:59:36.3199 TRACE: [FwHam][ExtractCallsign] : IU1QYV -> IU1QYV with prefix
2025-04-07 11:59:36.4021 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from EP7NIM
2025-04-07 11:59:36.4031 TRACE: [FwHam][ExtractCallsign] : EP7NIM -> EP7NIM with prefix
2025-04-07 11:59:36.4865 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from LU4DCW
2025-04-07 11:59:36.4865 TRACE: [FwHam][ExtractCallsign] : LU4DCW -> LU4DCW with prefix
2025-04-07 11:59:36.5390 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Executing planned scheduler...
2025-04-07 11:59:36.5396 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2025-04-07 11:59:36.5396 TRACE: [LogWriter][DumpProcess] : ## DUMP ##GetLog DbSqlite 1
2025-04-07 11:59:36.5407 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext dje_z3AL94SJ5BUMAZST9U72UYLLP26TQSCGYCW_ejd 1
2025-04-07 11:59:36.5407 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Planned scheduler executed...
2025-04-07 11:59:36.5676 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from 9M2DBY
2025-04-07 11:59:36.5676 TRACE: [FwHam][ExtractCallsign] : 9M2DBY -> 9M2DBY with prefix
2025-04-07 11:59:36.6515 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from KE8IGL
2025-04-07 11:59:36.6526 TRACE: [FwHam][ExtractCallsign] : KE8IGL -> KE8IGL with prefix
2025-04-07 11:59:36.7332 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from DO/PD7JV
2025-04-07 11:59:36.7343 TRACE: [FwHam][ExtractCallsign] : DO/PD7JV -> PD7JV with prefix DO
2025-04-07 11:59:36.8315 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from N7JMS
2025-04-07 11:59:36.8325 TRACE: [FwHam][ExtractCallsign] : N7JMS -> N7JMS with prefix
2025-04-07 11:59:36.9003 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from BG5VEC
2025-04-07 11:59:36.9003 TRACE: [FwHam][ExtractCallsign] : BG5VEC -> BG5VEC with prefix
2025-04-07 11:59:36.9821 TRACE: [ChatUsers][Drop] : Chat user dropped: K8GK
2025-04-07 11:59:37.0747 TRACE: [ChatUsers][Drop] : Chat user dropped: K8GK
2025-04-07 11:59:37.1414 TRACE: [ChatUsers][Drop] : Chat user dropped: K8GK
2025-04-07 11:59:37.2221 TRACE: [ChatUsers][Drop] : Chat user dropped: K8GK
Which version of Omnirig are your using 1.2 or 2?
M0TDW
Post by M0TDW »
using vV1.2
Bill
M0TDW wrote: 07 Apr 2025, 13:48 using vV1.2
Bill
Are you sure?
2 or 4 radios?
What other software is running?
M0TDW
Post by M0TDW »
Nord VPN ( I have deactivated this just in case and it didn't make any difference)
Dimension 4
Chrome
