I may have missed a set-up parameter here, so apologies if that is the case, but my question is....
When clicking on an incoming spot the 'worked bands' box (the box that can be detached) is populated to show what bands/mode that country has been worked on. That's fine; however is it possible to have that box filled *without* the need to actually click on a spot? In other words, whenever a spot appears the box is automatically populated to show what bands/modes the country has been worked on.
Further, is it possible that a 'detached box' can be completely moved from where its' normally located, in other words have it un-docked and freely moved and repositioned anywhere on the screen and not have the 'original' still remain in situ ?
Steve
GW4BLE
Worked Bands - Cluster spots
Re: Worked Bands - Cluster spots
If the latest spot triggered an update of the country worked pane then when the cluster is busy the speed of incoming spots would render the country pane unreadable.GW4BLE wrote:When clicking on an incoming spot the 'worked bands' box (the box that can be detached) is populated to show what bands/mode that country has been worked on. That's fine; however is it possible to have that box filled *without* the need to actually click on a spot? In other words, whenever a spot appears the box is automatically populated to show what bands/modes the country has been worked on.
Our user defined colour code provides exactly the information that you are asking for so having the country worked box working as you describe is not needed.
Sorry but it is not, this is because we will not use the Codejock libraries used in HRD because they are costly and unreliableFurther, is it possible that a 'detached box' can be completely moved from where its' normally located, in other words have it un-docked and freely moved and repositioned anywhere on the screen and not have the 'original' still remain in situ ?
