Filtering on a prefix on Cluster
LB2EG
Post by LB2EG »
I want to have spots with spesific prefixes to show up in the cluster pane (F9). Can anyone advice me where to find documentation on the programming syntax to use in the Regular Expression Editor in LOG4OM? The manual does not describe that on page 60 ff.
73 de LB2EG Richard
Re: Filtering on a prefix on Cluster
write here the prefix, i'll do for you and put here in the forum
LB2EG
Post by LB2EG »
IW3HMH wrote:write here the prefix, i'll do for you and put here in the forum
Thanks!
I like to get cw spots on norwegian hams from RBN, so I can say hello to old friends in between the DXing:)
So it will be prefix LA, LB, LI, LJ and LN.
73 de Richard LB2EG
Open Cluster screen, in CUSTOM tab press EDIT in the filters list
Create a NEW RULE and in the main area type:
^((LA)|(LB)|(LI)|(LJ)|(LN))
then select back and fore color, assign a description and press green V and then SAVE
LB2EG
Post by LB2EG »
IW3HMH wrote:Open Cluster screen, in CUSTOM tab press EDIT in the filters list
I tested this setup, but it does not do what I hoped it would, what is marking with colour the callsign or country of the spotted prefix.
The filter seems to search for the LA/LB etc. in the comment field, and gives colour to every comment field where the LA, LB etc. is part of any word.
Is it not possible to search for part of a callsign, or a DXCC entity, in the Callsign or DXCC fields?
regards
LB2EG Richard
Right, this filter works on comments only. My mistake on that.
Actually there are no regular expression filters that works on callsign. Maybe in a future version i will add this, but no plans in the short time because i'm fully on other parts of code
LB2EG
Post by LB2EG »
IW3HMH wrote:Right, this filter works on comments only. My mistake on that.
Ok. I can wait:)
Richard
LB2EG
Post by LB2EG »
Ok. I can wait:)
Richard
Is this filtering feature now on the TO DO list for a furure version of the program?
73 de Richard LB2EG
Yes it is.
Once several releases i will usually "rebuild" interfaces to make them more organized after subsequent patches and adds.
I will add this one as soon as i work on this interface, hopefully soon.
Our "to do list" has more than 100 small and big features/suggestions/bugs we're prioritizing and releasing every some weeks
LB2EG
Post by LB2EG »
IW3HMH wrote:Yes it is.
Thank you.
An alternative could be to make a timeline or watch-list, showing user defined watch items separate from the ordinary cluster spot window, as an user elected alternative or extension to the latest spots list.
73 de LB2EG Richard
