Kenwood TS-590 users
m0wmx
Post by m0wmx »
Hi all.
I'm wondering if anyone can help me with the settings for cat connection to my 590? I'm using hamlib but despite various setting changes I cant get the two to connect. Any help welcome.
Dave wmx
K7PT
Re: Kenwood TS-590 users
Post by K7PT »
I think your bet bet is to use Omni-Rig instead of Hamlib
m0wmx
Post by m0wmx »
OK so I'm trying that and still no good. I'm no expert on these things so excuse my ignorance. I'm using the same port I run fldigi from, in my case com3, is this correct?
Dave wmx
Dave,
You do realise that two programs cannot share a normal com port don't you
So if FLdigi is connected to the rigs com port Log4om will nopt be able to connect to that port because its already in use
m0wmx
Post by m0wmx »
Hi Terry.
Sorry, I should have made in clear that fldigi isn't running at the same time. My cat status button is green but I'm not getting any of the features. Scratching my head here.
Dave wmx
m0wmx wrote:Hi Terry.
Dave wmx
Are you saying that the frequency and mode do not change in Log4om when they are changed on the rig and that when double clicking a cluster spot in Log4om that the rig does not follow the frequency and mode.
Are you using the USB connection on the rig? if so I am surprised that the Silicon labs Kenwood port was installed to that com port number!
m0wmx
Post by m0wmx »
Hi terry.
All sorted. I've changed the usb port I was using on the laptop and its now working perfectly. Thanks for the advice pal.
Dave
