CW spot changes mode to CW-R on IC-7600
NN7D
Post by NN7D »
I know the band map or what controls the mode when clicking on a spot, has been covered here before, but have been unable to find it. When I click on a CW spot, the rig changes to CW-R mode, instead of CW. What file controls that mode, and or how can I get this changed so that the rig goes to CW mode?
Thanks,
Doug
W7DRM
Re: CW spot changes mode to CW-R on IC-7600
It's the Omnirig ini file that you need to modify
Program files/Afreeet/Omnirig/Rigs/
NN7D
Post by NN7D »
Well, with a little research and roaming around, I found the IC-7600.ini file under the Program Files...\Afreet\OmniRig\Rigs folder and found what I think is an error in the file. Checking the 7600 manual, the command for CW mode should have ended with 03. The entry in the .ini file for lower sideband CW was set to 03, while the upper sideband CW line ended with 07, which is for CW-R according to the 7600 manual. I changed the upper sideband entry to match the lower sideband entry. The mode now works correctly for CW!
Doug
NN7D
Post by NN7D »
Thanks Terry. I think we posted at the same time. That is what I concluded.
thanks,
Doug
g3yiq
Post by g3yiq »
I have the same problem. I found the file and where it needs to be changed but after making changes, it doesn't allow me to save the file saying I need the permission of the owner/administrator?
73 Bob G3YIQ
It's related to your windows security policy.
if you're not an administrator of the PC (or the current user is not an admin) you can't edit files in some "protected" folders of the PC
Try accessing with an user that is admin of the system to make the change
