Worked Before on Cluster Filters
m0lmg
Post by m0lmg »
Windows 11
v2.35.1.0
On the Cluster filters there is a 'Worked Before' Checkbox. As far as I can see this does not show countries that you have previously worked. Is it possible to consider an option to only hide 'callsigns' that you have worked previously.
Many thanks
Peter M0LMG
GU4XEA
Re: Worked Before on Cluster Filters
Post by GU4XEA »
One issue with this might be that I often work stations that I have worked before, recently in CQWW CW I worked several stations just to give them another country multiplier. In one case I worked a rare prefix station on the day before the contest (during setup I guess) and again in the contest the next day.
GU4XEA
