Hi, Log4om have good cluster filters, in: Cluster tab (windows filters)
It will be fantastic to add additional check box near three existent.
- Remove wrkd countries
-- Keep unworked band
-- Keep unworked mode on the band
-- Keep unconfirmed (slot?/mode-band) I think about paper QSL, LotW
73! Pawel SQ5LTL
Cluster filters
Re: Cluster filters
Try using the 'Highlights by changing from 'by country' to 'by LOTW or QSL not received'sq5ltl wrote:Hi, Log4om have good cluster filters, in: Cluster tab (windows filters)
73! Pawel SQ5LTL
Re: Cluster filters
Yes - Thank you, this solution is also good
73! Pawel
73! Pawel
Re: Cluster filters
Would be nice to see a Filter for only 1 call sign , or several calls . I mostly DX and contest and I try to work the DXpedition on as many bands as I can and would be nice to remove everything from the cluster except the DX callsign. Not just high-lite it...
Jay KB8O
Jay KB8O
Re: Cluster filters
You can do that already by sending a cluster filter command, see this for details of all possible cluster filter commands
http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
Re: Cluster filters
Terry good info... Is there a way to edit the pull down box menu in a text file so I can dump my own commands in it, the ones I use all the time instead of having to type them in manually???
Jay KB8O
Jay KB8O
Re: Cluster filters
Options/Select config tabKB8O wrote: 03 Jun 2017, 17:09 Terry good info... Is there a way to edit the pull down box menu in a text file so I can dump my own commands in it, the ones I use all the time instead of having to type them in manually???
Jay KB8O
Check the 'Enable expert mode' box
Edit the 'Cluster commands' list its a text file
Re: Cluster filters
I'm attempting to enter a set of permanent cluster filters which will load each time I connect to a cluster.
Here's the path I'm following:
Settings/Options/Enable Expert Mode/Cluster Commands
I then enter the filter commands I want to have run each time I connect, then save the file.
I then exit from Log4OM, re-start the program, and connect to the chosen cluster node, but the commands haven't run.
Can anyone help me identify what I'm doing wrong?
Thanks,
Kent, AE4Y
Thanks,
Kent, AE4Y
Re: Cluster filters
You only load a cluster filter once it then is maintained by the cluster until you send a command to the cluster to cancel the filter.
To learn how filters for clusters work I suggest that you read this
