Cluster filters
sq5ltl
Cluster filters
Post by sq5ltl »
Hi, Log4om have good cluster filters, in: Cluster tab (windows filters)
It will be fantastic to add additional check box near three existent.
- Remove wrkd countries
-- Keep unworked band
-- Keep unworked mode on the band
-- Keep unconfirmed (slot?/mode-band) I think about paper QSL, LotW
73! Pawel SQ5LTL
Re: Cluster filters
sq5ltl wrote:Hi, Log4om have good cluster filters, in: Cluster tab (windows filters)
73! Pawel SQ5LTL
Try using the 'Highlights by changing from 'by country' to 'by LOTW or QSL not received'
sq5ltl
Re: Cluster filters
Post by sq5ltl »
Yes - Thank you, this solution is also good :)
73! Pawel
KB8O
Re: Cluster filters
Post by KB8O »
Would be nice to see a Filter for only 1 call sign , or several calls . I mostly DX and contest and I try to work the DXpedition on as many bands as I can and would be nice to remove everything from the cluster except the DX callsign. Not just high-lite it...
Jay KB8O
Re: Cluster filters
You can do that already by sending a cluster filter command, see this for details of all possible cluster filter commands
http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
KB8O
Re: Cluster filters
Post by KB8O »
Terry good info... Is there a way to edit the pull down box menu in a text file so I can dump my own commands in it, the ones I use all the time instead of having to type them in manually???
Jay KB8O
Re: Cluster filters
KB8O wrote: 03 Jun 2017, 17:09 Terry good info... Is there a way to edit the pull down box menu in a text file so I can dump my own commands in it, the ones I use all the time instead of having to type them in manually???
Jay KB8O
Options/Select config tab
Check the 'Enable expert mode' box
Edit the 'Cluster commands' list its a text file
AE4Y
Re: Cluster filters
Post by AE4Y »
I'm attempting to enter a set of permanent cluster filters which will load each time I connect to a cluster.
Here's the path I'm following:
Settings/Options/Enable Expert Mode/Cluster Commands
I then enter the filter commands I want to have run each time I connect, then save the file.
I then exit from Log4OM, re-start the program, and connect to the chosen cluster node, but the commands haven't run.
Can anyone help me identify what I'm doing wrong?
Thanks,
Kent, AE4Y
Re: Cluster filters
You only load a cluster filter once it then is maintained by the cluster until you send a command to the cluster to cancel the filter.
To learn how filters for clusters work I suggest that you read this
