audio bug(?)
PA0AER
audio bug(?)
Post by PA0AER »
I can record and listen on file 2,3,4,5 and 6 but not in 1. When I try to write a text in file 1 I got sometimes an error message: unhandled exception. PC > W10
There is no buttton for the voice keyer controls in the icon bar
Re: audio bug(?)
PA0AER wrote: 05 Nov 2017, 12:21 I can record and listen on file 2,3,4,5 and 6 but not in 1. When I try to write a text in file 1 I got sometimes an error message: unhandled exception. PC > W10
Sounds like you have a corrupt audio file, delete the files in C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\audio and start again. I just tesed and it all works fine so this is all it can be.
Was moved to the Radio drop down menu to save space when we added the dual VFO display
PA0AER
Re: audio bug(?)
Post by PA0AER »
Re: audio bug(?)
Did deleting the files and starting over resolve your problem?
PA0AER
Re: audio bug(?)
Post by PA0AER »
Sorry, very busy these days, I will try it this evening
Ger
PA0AER
Re: audio bug(?)
Post by PA0AER »
I deleted the files. Now I have a message in the first 4 rows. But not after 2 crashes. Deleted again the files (except nr. 1) and finally it is working. But I cannot change the message by overwriting the old message. I need to delete the old message.
Re: audio bug(?)
Files are saved in your configuration folder (help > open configuration folder)
you can delete from there, or even register files with professional tools and sound editors and put those files on the folder, replacing the old ones.
