I can record and listen on file 2,3,4,5 and 6 but not in 1. When I try to write a text in file 1 I got sometimes an error message: unhandled exception. PC > W10
There is no buttton for the voice keyer controls in the icon bar
audio bug(?)
Re: audio bug(?)
Sounds like you have a corrupt audio file, delete the files in C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\audio and start again. I just tesed and it all works fine so this is all it can be.PA0AER wrote: 05 Nov 2017, 12:21 I can record and listen on file 2,3,4,5 and 6 but not in 1. When I try to write a text in file 1 I got sometimes an error message: unhandled exception. PC > W10
Was moved to the Radio drop down menu to save space when we added the dual VFO display
Re: audio bug(?)
Re: audio bug(?)
Sorry, very busy these days, I will try it this evening
Ger
Ger
Re: audio bug(?)
I deleted the files. Now I have a message in the first 4 rows. But not after 2 crashes. Deleted again the files (except nr. 1) and finally it is working. But I cannot change the message by overwriting the old message. I need to delete the old message.
Re: audio bug(?)
Files are saved in your configuration folder (help > open configuration folder)
you can delete from there, or even register files with professional tools and sound editors and put those files on the folder, replacing the old ones.
