QRZ Upload stopped working
DG7LAN
Post by DG7LAN »
Hi Folks,
my QRZ upload stopped working a month ago. I recognized it today though.
My API key is still the same in the config and on the QRZ page.
I don't know if the problem is related to QRZ or log4om (would be more my configuration than the program) but is there a way to debug the QRZ upload?
Kind of a hidden log file or command line option? I have no idea where to start from.
And by the way: I know, I can right click on a single QSO to force upload to QRZ. Is there a way to do it with a selection of QSOs? (Other then exporting to adif and upload manually)
Thanks for your help,
Andy
Re: QRZ Upload stopped working
Using you call sign as a user name might have helped us with your issue but as it is I can't check QRZ!
Did you check that your paid for QRZ XML subscription has not expired?
Did you check that your logbook end date in QRZ is still a valid future date?
Did you check the Log4om log file (help/show log) for errors?
DG7LAN
Post by DG7LAN »
Hey Terry,
I tried to use my call as the username but I could not get the activation link. Thats why I registered again to place my (dumb) question.
Really sorry for wasting your time. The subscription did indeed time out. :I
Thanks for pointing me to the debug log. Was it always there under "help"? Fantastic and verbose enough to see whats going on under the hood.
Have a nice day and thanks again, Andy / DG7LAN
Do you want me to edit your user name to your call sign?
DG7LAN
Post by DG7LAN »
That would be nice.
Can you delete the old account? Its registered with dg7lan at gmx.com (should be)
73 Andy
Done
Impossible things would be done in realtime ... only wonders need a bit longer ... :D :D ;)
