pst rotator
it9imj
pst rotator
Post by it9imj »
salve a tutti o configurato log4omv2 ma no riesco fare funzionare pst rotator.73 rosario
G3ZSS
Re: pst rotator
Post by G3ZSS »
Make sure you have the same UDP port selected between PSTRotator and Log4OM2, as well as "Tracking" turned on in PSTRotator.
It works fine here.
Settings PST.PNG (14.24 KiB) Viewed 6755 times
73 Peter G3ZSS
m0pkz
Re: pst rotator
Post by m0pkz »
Peter thank you. Also how did you changed so the map apears on direction screen?
Kes-m0pkz
G3ZSS wrote: 20 Jan 2020, 10:23 Make sure you have the same UDP port selected between PSTRotator and Log4OM2, as well as "Tracking" turned on in PSTRotator.
It works fine here.
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
G3ZSS
Re: pst rotator
Post by G3ZSS »
If you are referring to this overlay map in PSTRotator
Then I created the map by using a programme called Aziworld by F6DQM. You should be able to quickly find it by searching the web. Save the map as Azimuthal.bmp and place this file in the folder \PSTRotatorAz\Maps\
Hope this helps?
73 Peter G3ZSS
it9imj
Re: pst rotator
Post by it9imj »
salve a tutti mi da questo error 73.rosario
HB9VQQ
Re: pst rotator
Post by HB9VQQ »
Is your PST and Log4OM running on the same Computer ?
Flex 6600 - Spiderbeam
N8HO
Re: pst rotator
Post by N8HO »
Is there a more detailed setup instruction for setting up PSTRotor I cannot figure out how to enter information or select it, to "fill in" the UDP outbound Connections box.
N8HO
Re: pst rotator
Post by N8HO »
Sorry...finally figured it out.
it9imj
Re: pst rotator
Post by it9imj »
udp 12040 configurato con il log4omv2 settaggi coretti come mi dice log4
set upd 12040 spunto setup udp control tracker spunto log4om ,appena trancking ,mi dice log4om tranckig error
it9imj
Re: pst rotator
Post by it9imj »
