pst rotator
pst rotator
salve a tutti o configurato log4omv2 ma no riesco fare funzionare pst rotator.73 rosario
Re: pst rotator
Make sure you have the same UDP port selected between PSTRotator and Log4OM2, as well as "Tracking" turned on in PSTRotator.
It works fine here.
It works fine here.
73 Peter G3ZSS
Re: pst rotator
Peter thank you. Also how did you changed so the map apears on direction screen?
Kes-m0pkz
Kes-m0pkz
G3ZSS wrote: 20 Jan 2020, 10:23 Make sure you have the same UDP port selected between PSTRotator and Log4OM2, as well as "Tracking" turned on in PSTRotator.
It works fine here.
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
Re: pst rotator
If you are referring to this overlay map in PSTRotator
Hope this helps?
Then I created the map by using a programme called Aziworld by F6DQM. You should be able to quickly find it by searching the web. Save the map as Azimuthal.bmp and place this file in the folder \PSTRotatorAz\Maps\Hope this helps?
73 Peter G3ZSS
Re: pst rotator
salve a tutti mi da questo error 73.rosario
- log4omvrosario2.jpg (170.35 KiB) Viewed 6712 times
Re: pst rotator
Is there a more detailed setup instruction for setting up PSTRotor I cannot figure out how to enter information or select it, to "fill in" the UDP outbound Connections box.
Re: pst rotator
Sorry...finally figured it out.
Re: pst rotator
udp 12040 configurato con il log4omv2 settaggi coretti come mi dice log4
set upd 12040 spunto setup udp control tracker spunto log4om ,appena trancking ,mi dice log4om tranckig error
