ADIF File Input from N1MM Plus
G0PZA
Post by G0PZA »
Hi Terry
I exported a file (about 2300 records) from N1MM plus, as an ADIF file; Imported into L4OM fine, except that I ticked the box to add the countries, but my countries column is blank! Any ideas?
Garo G0PZA
Re: ADIF File Input from N1MM Plus
Please email me the N1MM ADIF file
G0PZA wrote:Hi Terry
Garo G0PZA
Hi Garo,
Thank you for sending me the N1MM ADIF file which of course does not contain either the DXCC number nor the country name, I would have expected this to have been rectified in the new N1MM but apparently not!
I imported the ADIF file into an empty Log4OM logbook, having checked the box "Update Countries in ADIF" in our ADIF import window and as you will see from the screenshot below the countries and DXCC were all updated OK
There were however 10 entries that had odd call signs like SW7GRM, UA2 with no suffix letters and DL-SWL/DE1PCE which of course no logging software is going to recognise also a 2Ezero call that was entered as a 2EO :D but these few you can manually edit easily
So the question remains, why did you have a problem?
What version of Log4OM are your using?
What operating system do you have?
Did you fix it or do you still need help?
