Stuck ADIF Export in Process... Message
ka3qot
Post by ka3qot »
I'm exporting an ADIF file of 949 records.
I name the file, select Write ADIF File and the ADIF Export in Process message appears....
It's been stuck like this for almost 15 minutes. How long should it take to process 949 records? Can I just close the Export ADIF box?
I've tried this several times with the same result? It just hangs.
Any suggestions?
Thank you.
Re: Stuck ADIF Export in Process... Message
I believe that you will find the "Completed" message is hidden behind the main window, close the export window and check if the file was created
ka3qot
Post by ka3qot »
Hi - This happens when exporting .csv files, too. Can you do a screenshot of where the completed message appears? I can't find it.
Thanks.
Try minimising the main window, you should see this
Where are you exporting file? Did you have write permission on the folder? Log4OM took about 0.4sec to export 1000 qso..
