When entering a qso and specifically the mode, I learned a lot about the evolution on digital communication
Not really my peace of cake (getting old I guess)
Is it possible to limit the choice of modes to the ones I use?
I was exploring this with a view to adding as well as deleting modes.
Currently, it is set to be the LibreOffice 5 spreadsheet. On the first press of the mode list button I got an error message and each subsequent press brought up the LibreOffice 5 text import dialogue from which the file would open.
Could you please let me know which program would be best to use to open/edit this .csv and which column is the one or ones to edit? I have attached a small image of that shows this end.
Mni tnx es 73.
Which column does one edit? I have opened the file with notepad and each mode is listed four times; more often than not each mention is identical to the last.
Just a side question...if one were to edit the file in wordpad etc, would the addition of formatting information make the file unusable by Log4OM?
With warmest regards
Guy
Terry, what do I do if I want to add a mode (e.g. FSQ) as not all columns are identical (like the Domino examples in your screenshot)?
>>It's a plain text file any formatting will render it useless.
I just wanted to double-check as you mentioned using Wordpad for editing. Also, Wordpad will add the RTF extension after .csv unless one is careful (I use "s to prevent this).
Regards
Guy
