K5P contact upload to QRZ logbook
Re: K5P contact upload to QRZ logbook
I have an adequate QRZ subscription; I have uploaded right-clicking on the QSO in the past and am only having an issue with this specific contact.
According to this you do not have a membership that allows automatic API upload - You are only an 'Ham member' which is a free unpaid subscription
Read the QRZ link in my last posting
Possibly your subscription has expired???????
N8MSA
Post by N8MSA »
Dear Michael Alexander, N8MSA,
Your QRZ Subscription has been activated and is ready for use --
Your subscription: QRZ Premium 1 Year, --
Now expires on 2016-11-16
Your new subscription is active immediately. Your new user title (if applicable)
will be updated within 24 hours.
N8MSA wrote:Dear Michael Alexander, N8MSA,
Best speak to QRZ because as you can see you are only registered as a ham member, seems something went wrong at QRZ with your subscription
N8MSA
Post by N8MSA »
I confirmed my subscription status with QRZ - I'm not sure why your screencap shows otherwise - and I just successfully uploaded a new contact to QRZ. This problem seems to be confined to K5P.
Not just my screen capture, check a lookup of your call on QRZ you will see it still shows you as a ham member
I now have your SQLite file and will check more and revert to you
N8MSA
Post by N8MSA »
Per W1DG at QRZ:
Only XML and higher subscribers have export (download) privileges whereas all members have import (upload) privileges. Further, only XML and higher subscribers can share their logbook with managers.
If Log4OM needs clarification, they can request same from https://ssl.qrz.com/support
A quick review of the site shows that most paying member's accounts show "ham member" but the differentiator seems to be the color of the QRZ badge on the member's page.
And I made a contact after my K5P contact which uploaded via the Log4OM contact context menu successfully.
EDIT: I was going to screen-cap my QRZ log page and guess what appeared...my K5P contact. I suspected that this was a problem on the QRZ side all along.
Is there a mechanism that I can use to monitor external service uploads such as this?
N8MSA wrote: I was going to screen-cap my QRZ log page and guess what appeared...my K5P contact
The reason that k5P suddenly appeared is because I have been working on your logbook and set up!
I have tried uploading QSO's to your QRZ account using the API method and everyone fails to upload, regardless of the call sign
However doing a Log4OM export of a QSO and then importing it manually on the QRZ web site works fine, including K5P
As you are the only person reporting this issue also when I do a QRZ API upload from my own logbook it works faultlessly therefore I have to assume there is something wrong with your QRZ account.
Unfortunately QRZ do not return an error report detailing the issue as some other online logbooks do all we receive is the following:
STATUS=FAIL&REASON=missing <eor> in record&EXTENDED=
Which does not tell me much
Help - Show real time log
I will study this further but I firmly believe that although your membership is paid and current that something is not enabled on the QRZ logbook database by QRZ which is blocking the API upload
Stand by, I have found something strange :o
Probably cant check further until Monday when Lele is back
K7PT
Post by K7PT »
For some reason, it's not seeing the end of record.
K7PT wrote:For some reason, it's not seeing the end of record.
No its the bit before 'Missing'
