N8MSA wrote: I was going to screen-cap my QRZ log page and guess what appeared...my K5P contact
The reason that k5P suddenly appeared is because I have been working on your logbook and set up!
I have tried uploading QSO's to your QRZ account using the API method and everyone fails to upload, regardless of the call sign
However doing a Log4OM export of a QSO and then importing it manually on the QRZ web site works fine, including K5P
As you are the only person reporting this issue also when I do a QRZ API upload from my own logbook it works faultlessly therefore I have to assume there is something wrong with your QRZ account.
Unfortunately QRZ do not return an error report detailing the issue as some other online logbooks do all we receive is the following:
STATUS=FAIL&REASON=missing <eor> in record&EXTENDED=
Which does not tell me much
Is there a mechanism that I can use to monitor external service uploads such as this?
Help - Show real time log
- Untitled.jpg (50.19 KiB) Viewed 5712 times
I will study this further but I firmly believe that although your membership is paid and current that something is not enabled on the QRZ logbook database by QRZ which is blocking the API upload
