Yesterday i uploaded some qso to qrz.com by log4om, Than i checked on qrz.com webpage on browser, QSO time was incorrect,
for ex.real qso time UTC: 16:40 - Qrz log bokk same qso time is UTC: 00:00
What is the problem, How can is solve this
qrz.com time
Re: qrz.com time
You probably have your computer clock time zone set incorrectly
Log4OM logs in UTC/GMT/Zulu time not local time and obtains the time from your computer clock and time zone -
Re: qrz.com time
Hi Terry thanks for quick reply,
i checked my time zone settings but it seems normal. On log4om time is correct. Please look below pic.
- qrztime.JPG (100.19 KiB) Viewed 7446 times
- log40mtime.JPG (96.56 KiB) Viewed 7446 times
Re: qrz.com time
Was this an automatic upload to QRZ or did you manually upload by a right click on the QSO in the F8 recent QSO screen?ta1o wrote:Hi Terry thanks for quick reply,
I notice that previous QSO's in your screen shot show what seems to be the correct time????????
Re: qrz.com time
I send manually log (TA8L) to qrz.com but it is same, wrong time,
Before qso, i send the adif import process, so these ones have correct time.
Thanks 73s TA1O
Thanks 73s TA1O
- qrztime1.JPG (164.2 KiB) Viewed 7441 times
Re: qrz.com time
I just tried a manual upload of a single QSO to QRZ and it uploaded with the correct time so I think the issue is with some set up on your computer.
In Log4OM
1. Enable trace mode - Help/Debug Mode/Trace
2. Then do another manual upload to QRZ
3. Finally send me the logfile - (Help/Show log) by email
DO NOT POST YOUR LOGFILE ON THE FORUM IT CONTAINS YOUR PRIVATE INFORMATION
In Log4OM
Re: qrz.com time
Thanks for advice,
i send to log to g4pop AT arrl.net mail adress.
PLEASE DO NOT PUBLISH EMAIL ADDRESSES ON WEB SITES TO AVOID SPAM AND HACKERS
73s
73s
Re: qrz.com time
The time uploaded by Log4OM to QRZ is correct as confirmed in the log file line belowta1o wrote:Thanks for advice,
73s
2016-04-29 12:55:45.5043 INFO: QrzComUpload: UPLOAD begin upload QSO to QRZ.COM Call: TA2DX Date: 20160429 Time: 125532 Band: 20m Mode: SSB
Later in the log file you try to upload the same QSO a second time and it's rejected as a duplicate, this is what should happen!
There is the possibility that there is a problem at QRZ??? Have you contacted QRZ?
You are not running Log4OM with administrator privileges I suggest that you reinstall the program correctly! This will not fix the QRZ issue but it will ensure the software runs correctly in other areas.
Re: qrz.com time
hello,
i reinstaled log4om and changind computer time zone settings, but problem is go on,
What can i try next?
