Hello Anybody.
I just can't get CAT control working to my new IC-7100.
Tried to select fx IC-7000 and adjusted hex-values and comport, but no good!
IC-7100 is not on the list of selectable radios in * Log4OM CAT*
It is my first ICOM not being able to do this.
Previous IC 706, 7000, 756Pro3, IC7600 all successfull CAT.
Best regards
OZ8PG
Per
ICOM-7100 CAT control
Re: ICOM-7100 CAT control
Per,
Please use Omnirig latest version and also latest Omnirig rig ini files
Select IC-7100e4 and then you will see both of the 7100 VFO's as the screen clip of my IC7100
Many thanks for your information.
Glad to hear there is a solution to this problem!
I have downloaded latest version Omnirig inclusive ini- files.
How do I setup the CAT .
The new list of ini-files - how to do with it ?
Best regards
OZ8PG
Per
Best regards
OZ8PG
Per
Dr OM G4POP
I have solved the CAT setup problem with Omnirig to IC-7100.
The CAT control works super and just as you showed me.
Again many thanks !
OZ8PG
Per
Again many thanks !
OZ8PG
Per
