eQSL Upload Date Incorrect In Log4OM
ab1xg
Post by ab1xg »
I started noticing Log4OM is logging the wrong QSL upload date for eQSL's. Upload dates for LoTW are correct. See attachment. Compare the QSO date and time to the eQSL sent date.
Note that this error (?) only seems to affect the log, the actual QSL on eQSL.cc has the correct date. A QSL match is possible.
Am I doing something wrong?
David AB1XG
Re: eQSL Upload Date Incorrect In Log4OM
Have you set Log4OM to upload to eqsl automatically or are you uploading them manually by using a right click on a QSO record?
ab1xg
Post by ab1xg »
eQSL is supposed to upload automatically.
Yesterday I had 5 QSO's that did not upload to eQSL automatically. They also did not upload to HRDLog.
Strange .... Settings for both still say they're supposed to upload automatically.
The failure to upload just started yesterday.
I was able to manually upload them.
ab1xg wrote:eQSL is supposed to upload automatically.
Seems that you have an issue with either incorrect eQSL/HRDLog user names, passwords or nickname in the case of eQSL or you lost internet connectivity.
I have checked this with version 1.25 and 1.24 and it works correctly so the problem is with your set up somewhere
Your upload date is probably different to the QSO date because you are updating at some later date manually, it does not effect the validity of the eQSL data because its the QSO date that is important - Not the date it was uploaded
ab1xg
Post by ab1xg »
Yes, maybe I did lose connectivity, tried again today and my QSO's uploaded as expected to eQSL & HRDLog.
So back to the original issue. Why does it sometimes display an incorrect date for the eQSL upload? The actual eQSL on the web site has the correct QSO date but my log shows the day earlier.
I haven't made any changes to any QSL accounts online and I've made no changes to my Log4OM configuration in months. Running Windows 10 and the latest Log4om.
