Cluster Tweaking - "Custom"
Is the "Custom" tab for the Cluster (F9) the location to develop a file to look for specific callsigns?
If that is the case what would be my nomenclature or verbiage for such?
My prior logging program had a limited capability to "look" for a 'few" callsigns.
This is quite helpful for a limited special event that uses specific callsigns.
I can't seem to land on a path for such selectivity via VE7CC to get to that detail so was wondering if Log4OM could provide a few more steps to get to that detail.
Thanks in advance.
Re: Cluster Tweaking - "Custom"
The custom tab searches the 'Comment' field so of no use if your checking for a call sign
Use the call field perhaps
If you were using the DX Spider spots you could filter by call as in this filter command list
http://www.dxcluster.org/main/filtering_en.html
