Cluster Spotting
G1XRJ
Cluster Spotting
Post by G1XRJ »
Good afternoon,
Hoping I might be able to get a quick answer to something that I'm struggling with.,
I have made huge leaps today in setting up Log4OM with cat control, so that I can jump straight to a Station on the cluster, and the radio auto-selects freq and mode etc.
I note also, that the freq & call sign thus self populate ready for me to only press "ADD" to log the contact.
After I have completed the contact and pressed "ADD" to log it, Is there a quick way to post MY contact on the cluster.?
At the moment I cannot see I way to do this.
Steve
Re: Cluster Spotting
You cant send a spot to the cluster after you have added the QSO, you should send the spot during the QSO, see below
G1XRJ
Post by G1XRJ »
Brilliant, I knew it must be in there somewhere,
Much appreciated, Terry.,
Been really surprised by the capability of Log4OM
I've realised I've been only using about 10% of its functionality.
Steve G1XRJ
G1XRJ
Post by G1XRJ »
Tried this today, and I do not see my spots posting to the cluster.
Also I see that unless the information box is empty, then the send becomes disbled
Am I missing something.??
pic 2.jpg (38.03 KiB) Viewed 2709 times
i'll check, but probably the cluster itself doesn't echoes the spot back to the sender.
If you open the realtime log from help menu you should see the spot going out... if not, increase log level to DEBUG (from help menu)
Any issue will be reported in the log file
