Statistics and Awards no longer works
kb0kfx
Post by kb0kfx »
I upgraded from version 1.24 to 1.26 and now the "Statistics and Awards" no longer runs. I tried reverting back by installing the old version and that no longer works either. My logs are still shown. Is there something I need to reload after updating?
Here is a snippet of Show Log.
2017-03-21 03:14:28.0598 INFO: FileManagement: AWARD LIST begin load
2017-03-21 03:14:28.0638 INFO: FileManagement: AWARD LIST load completed
2017-03-21 03:14:28.1398 ERROR: *** Log4OMMainWindow: Object reference not set to an instance of an object. ******* [Function: #=qHVOatYpNYTqUtdnRIvHCtvAbsfZVIhM2Bgzd68BhbDo=] System.NullReferenceException: Object reference not set to an instance of an object.
at AwardControl.LocatorAwardControl..ctor()
at LogOMUI.FormStatistics.#=qFQrSTGDeS6x1N9ZTSFy6rHIHrvb4oSJi3Rnd9sztx0w=()
at LogOMUI.Log4OMMainWindow.#=qHVOatYpNYTqUtdnRIvHCtvAbsfZVIhM2Bgzd68BhbDo=()"
Re: Statistics and Awards no longer works
Is it that the awards window does not appear or that specific awards are missing?
The latest version is 1.27 please download and install that version and then..............
In Log4OM.... Settings/Awards database/download updates
kb0kfx
Post by kb0kfx »
The window does not appear.
kb0kfx wrote:The window does not appear.
Sounds like a bad download or install or a coruped configuration file
Try a fresh download of 1.27
Uninstall the version you have installed and re-install V1.27
Don't forget it must be installed as 'Run as an Administrator' by right clicking on the installer
Don't go looking for V1.28 its an Alpha test version, the latest is 1.27
kb0kfx
Post by kb0kfx »
Thank you. Ill give that a try.
Is there more than just the one log file native to log4om that i should backup that has config data?
kb0kfx wrote:Thank you. Ill give that a try.
Use our automatic backup which backs up the configurations also
It seems something bad in your data...
Please zip and send your log (sqlite) to iw3hmh (at) pisto (dot) it
kd8atf
Post by kd8atf »
I am having the same issue here! The Statistics and Awards window will no longer open.
Here is my log!
2017-04-02 17:13:04.7758 INFO: Log4OMMainWindow: *Calling STATISTICS FORM*
2017-04-02 17:13:04.8378 INFO: FileManagement: VIEW CONFIGURATION begin load for Statistics
2017-04-02 17:13:04.8528 INFO: FileManagement: VIEW CONFIGURATION load completed
2017-04-02 17:13:04.8758 INFO: FileManagement: VIEW CONFIGURATION begin load for Statistics
2017-04-02 17:13:04.8888 INFO: FileManagement: VIEW CONFIGURATION load completed
2017-04-02 17:13:04.9898 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.0028 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.0528 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.0668 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.1188 INFO: FileManagement: begin load text file C:\Users\future\AppData\Roaming\LogOM\WAS.csv
2017-04-02 17:13:05.1288 INFO: FileManagement: Text file load completed
2017-04-02 17:13:05.1388 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.1548 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.2348 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.2458 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.3338 INFO: FileManagement: begin load text file C:\Users\future\AppData\Roaming\LogOM\continents.csv
2017-04-02 17:13:05.3448 INFO: FileManagement: Text file load completed
2017-04-02 17:13:05.3548 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.3658 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.6878 INFO: FileManagement: AWARD LIST begin load
2017-04-02 17:13:05.7038 INFO: FileManagement: AWARD LIST load completed
2017-04-02 17:13:05.7588 ERROR: *** Log4OMMainWindow: Object reference not set to an instance of an object. ******* [Function: #=qO7hxtYjMaHFNwVNBX1qnrkFmYzEB9po0aRacQhrJChI=] System.NullReferenceException: Object reference not set to an instance of an object.
at LogOMUI.FormStatistics.#=qbJdQz76AzfQRjRb7Vvi53oXVfoT7E_dvWeuCbTnclow=()
at LogOMUI.FormStatistics..ctor()
at LogOMUI.Log4OMMainWindow.#=qO7hxtYjMaHFNwVNBX1qnrkFmYzEB9po0aRacQhrJChI=()
kb0kfx
Post by kb0kfx »
I sent the sqlite database per the recommendation above..
I uninstalled the previous version and installed 1.27 as administrator with no luck on the statistics feature working again.
kb0kfx
Post by kb0kfx »
I just tried a sqlite log backup from a year ago and it still has the same error as my initial post when i run the statistics feature. This tool stopped working days before my first post to this thread.
