Cluster Statistics list
KA4CDN
Post by KA4CDN »
How do I set which bands to include on the Statistics tab when viewing a spot on the F9 Cluster list? I'm missing 17m.
Re: Cluster Statistics list
Options/ CAT & Cluster
KA4CDN
Post by KA4CDN »
I would have thought so but what I have selected there is not what is available in my filter listing.
I've restarted more than once.
KA4CDN
Post by KA4CDN »
Further testing ...
Those "Cat & Cluster" "Cluster filter" selections do change the available Bands in the drop down on the Filters tab (after save and restart) but are not changing the options on Statistics tab.
If you have selected the 17 m checkbox have you saved it with the disk button right beside the printer button ?
All the bands i have selected i see in the cluster stats.
P.S. after saving it restart again.
KA4CDN
Post by KA4CDN »
Yes. And restarted Log4OM.
My list of Band filters gets updated but not the Statistic list. And my screen shot shows my selection and the rows on the Statistics tab (after saving and restarting Log4OM).
KA4CDN
Post by KA4CDN »
I just did the entire sequence again.
I unchecked 160, in the setup Cat & Cluster. Saved. Shutdown Log4OM and restarted it. The Bands available on the Filter tab no longer have a 160 selection but the Statistic tab still does. Yet you said yours worked?
Mike / KA4CDN
Version 1.27.0.0
Hi Mike,
here all is working fine (using latest 1.28 but the versions before doing it too). I can check and save, i can uncheck and save and after a restart i have the actual bands in the statistics.
B.t.w. are u running Log4OM with administration rights ?? Could be possible that changes wouldn´t be accepted if you don´t have installed L4O as administrator.
Only an idea ;) ;)
KA4CDN
Post by KA4CDN »
This is very strange (and frustrating) then. Yes, I'm running with Admin privilege under Win7.
I'm assuming your Band selections under Filter are following the your configuration selections too right? That is what is so strange here; that those are following my configuration but not the statistics.
Have you tried a fresh download and install?
