Not connected to any database or database ereror
Getting this error when I attempt import adif. I created a new DB with a different name and now I can't connect to it or my old one? Same error and no QSOI's show up in either. I dont get any error when I open either database. Is the error logged somewhere else? thanks.
Re: Not connected to any database or database ereror
What message does Log4OM display in the lower right hand corner of its main window - See below
It says not connected. I removed log4om and installed the portable version thinnking something from the other version was left behind. If I unstalled and thenm reinstalled the program it would display some error about culture?
. Did initial config of station and launched. It said not connected. Created a new DB. No message eg db created ? Still not connected. When I click on 'not connected' in lower right cvorner it displayed the dialog box shown in pic.
https://1drv.ms/i/s!AnNj5BGVM8slgcML-mprsRinjcOA2w Not sure that image casme thru.
thanks.
thanks.
If you have created a new DB have you connectet to it manually
at the first time ??? Open Log4OM klick on the "File" Menu an klick
on "Open Database" .... In the context menu find your new created
DB ans double klick on it.
After a later new start L4O will connect automatic to those DB ...
