ADIF import problem
IV3DXW
ADIF import problem
Post by IV3DXW »
I'm trying to import my log with ADIF file and I found up to now the following mismatches:
1. QSL send/received status is R whem my ADIF record has this data missing. I expect to be N
2. <DXCC:3>NNN is correctly imported but country name is not associated. I would keep this data as in my actual logger
3. even all <DXCC:3>NNN data are correctly imported, my AWARD DXCC status has many country missing across varius bands (my log has >38000 entries)
Many thanks to anybody might help me, becuase I would like to make hand-off to this logger for all the interesting features supported.
Best 73
Claudio IV3DXW
Re: ADIF import problem
What software did the ADIF come from?
Hello Claudio,
to point 1) Go to Settings/Options/QSL and Labels and turn the QSL Defaults to what you want.
After changing press the Diskette symbol to save the changes ....
to point 2) If you importing an ADIF make shure that the checkbox "Update countries in ADIF" is
checked. For now delete all entries in your log that you have imported and do a fresh import
with this box checked ...
to point 3) First make the changes for the first 2 ponts. Could be possible that the problem in point
3 is solved too ....
IV3DXW
Post by IV3DXW »
I'm trying to migrate from easylog.
Hi Jurgen,
OK for 1), I can change default from R to N. I will try it. Thanks.
About 2) of course I have tried to make "country update" and took a lot of time for 38000 qso...
But I would try to avoid this and I prefer to keep all my DXCC countries as defined in my current logger.
If there is no way to make association with <DXCC:3>NNN field.... then OK I'll do and I will find the way to compare what log4OM assigns and what I have in current logger in order to locally correct only (hopefully) some QSO.
About 3) actually even in my try with "Update countries in ADIF" I did't replicate the same country list I have in my current logger. Many country are missing in different bands. This is now my major concern to proceed in migration.
Since I have a lot of more info in my current DBF file, I would create an "ad hoc" ADIF to import all of them in LOG4OM.
Best 73 and thanks for help
Claudio IV3DXW
IV3DXW
Post by IV3DXW »
Hi all!
Yestarday I started again from scratch the import.
At the end I have almost all DXCC worked and confirmed status.
There are about 30 mismatches (over 2000 entries of DXCC challenge) that I will check one by one.
I had made this time the import with TRACE enabled (really nice feature!) to debug.
I will post some findings if interesting.
Best 73
Claudio IV3DXW
