fldigi
PA0AER
fldigi
Post by PA0AER »
I was trying to integrate fldigi (and later JT65/FT8) but the description in the manual (page186) is differtent with my installation. I can communicatie with other software, have a MySQL database, but do not see settings for the communicator.
K7PT
Re: fldigi
Post by K7PT »
Hi Geert,
Are you running Log4OM with Admin Priv?
What is your call sign?
We like to know for what region your in to serve you better. Thanks.
Re: fldigi
Hi Geert,
if you have started Log4OM the Communicator is an own program with it´s own symbol in the
taskbar, it looks like a blue marbel or so. You have to open the communicator and hit the red
STOP button to make the changes you have to setup (like described in manual from page 186).
After setting up you have to hit the START button and you can minimize the communicator to
the taskbar.
Note:
You have to close Log4OM and Flidi now. Now you can restart both programs but you have to
start Fldigi first followed by Log4OM. In the other way it would´t be work.
If you need to integrate WSJT-X also se this thread: viewtopic.php?f=10&t=3138
By the way, as Chuck said, Log4OM must be run with administrator privileges to make all features
possible.
PA0AER
Re: fldigi
Post by PA0AER »
Thanks, I have now see the communicator, it was hided in the taskbar.
I'm running log4om as administrator and have a link with flexsatpc
My call is pa0aer, i will try to change the name in the profile
Re: fldigi
Hi Geert,
you can´t change the username ... I ask Terry (G4POP) to do this.
Note:
There will only the username be changed and not your password. So
if Terry has changed Username to your call you have to login with your
callsign but your original password.
PA0AER
Re: fldigi
Post by PA0AER »
TNX Juergen
K7PT
Re: fldigi
Post by K7PT »
Geert,
I have changed your user name to your call sign---PA0AER
Use this to log into the forum
PA0AER
Re: fldigi
Post by PA0AER »
Thanks!
Re: fldigi
Perhaps a picture of the set up might assist
PA0AER
Re: fldigi
Post by PA0AER »
Thanks Terry.
FLdigi is working now here. I have as transceiver a FLEX-6500. When I have some time this afternoon I will Install also FT8/JT65.
I let you know when everything is up and running. I like Log4OM, I'm migrate from DXlab.
