I have a few thousand qsl cards sorted by call. I want to now indicate that I have received these cards, QSL status = Y. Having clicked on call sign, the call signs are now sorted alphabetically. But once I've made a change to the qsl status, the list will be sorted by date. Can I change this, or is there a simpler way to make the information, for example, by editing directly in the table?
Thanks in advance, Ger
editing table
Re: editing table
enter the call sign in the search box at top left of the QSL manager window and click the return (Enter) key on the keyboard
Select the required QSO and then click the update save diskette icon having set the source and date fields
Repeat
I can update 3 to 4 cards a minute this way
Watch the YouTube tutorial about this
Repeat
Re: editing table
I found a better way:
export the database as an adif
search on the Internet for a program with the name "ADIFMaster", Install the program. Load the adif file and edit the fields.
save the file as adif with a new name
Delete the database (learn it on this Board from PB4FUN):
"QSO Archive - Archive Management - Field update (no rows selected msg, click away)
On the right in the field above the red labels enter : delete from log
Check the checkboxes from the red labels and press the "I understand ...."-button "
Import the new adif file.
I have more then 2000 entries edited within 3 hours.
Re: editing table
That is a very convoluted and time consuming way of doing it! The built in facility is much faster - see the YouTube video about how to do this
Re: editing table
where can I find that YouTube movie?
Re: editing table
A Google search for Log4OM YouTube or Log4OM tutorial will reveal all, but here is the list scroll down to Log4OM Paper QSL
EDIT
Just in case you think its only about outgoing card, handling incoming cards starts about 5 minutes into the video
Re: editing table
Terry, you are perfectly right for a handful of qsl cards. but not when it comes to 2000+ cards, with plm 1000 times only 1 column being changed from Y to N. Thanks for the adresses of the YouTube movies. This is a very nice feature, that confirms again that log4om was a good choice for me.
Re: editing table
Not wishing to be argumentative but I still believe the thousands of QSL's can be handled easily in Log4OM by perhaps using the QSL Manager as followsPA0AER wrote: 13 Nov 2017, 10:55 not when it comes to 2000+ cards, with plm 1000 times only 1 column being changed from Y to N.
1. Narrow down the number of QSO's to be displayed by using the 'Search Parameters' in the Log4OM QSL Manager window to select just those QSO's that have not received a card QSL received Status is N-no as below
2. Sort the resulting list by call sign - Click the column header title to do that
3. Select the QSL Received field to Y-Yes(Confirmed), the QSL Rcvd via to the method by which the cards were received and set the QSL Rcvd date
4. Using the Widows method of Ctrl/Left Click and the scroll feature proceed to select those cards that you already have cards sorted for - Perhaps a batch of 50/100 at a time.
5. Click the small diskette icon alongside the QSL Rcvd date and all the highlighted QSO's will be updated accordingly
Repeat item 3, 4 & 5 until the job is done
EDIT
You could of course use the 'Search' facility at the top of the QSL manager as below if you prefer because you can inhibit the 'Refresh' after save but I personally prefer the other method
Re: editing table
Thinks Terry, I will try it.
Re: editing table
if you have SQL knowledges you can do a SQL update on database.
We need to know what are the "filter parameters" so i can help you writing a correct SQL query via Log4OM interface
