qsl recieved via bureau
vk4tjf
Post by vk4tjf »
hello I'm currently using n3fjp ac log and it has qsl via card
when I upload my adif file it does not recognise this and
does not say that I have qsl via the buro with any of my contacts
any way of fixing this?
Re: qsl recieved via bureau
Email me the n3fpj adif file to g4pop (at) arrl.net and I will check what's happening
vk4tjf wrote: 06 Feb 2018, 14:52 hello I'm currently using n3fjp ac log and it has qsl via card
I just imported the ADIF file that you sent me into Log4OM and the QSL Status for sent and received is being displayed fine, see screen grab below.
However the N3FJP ADIF file does not contain the following information
QSL received via
QSL sent Via
QSL received date
QSL sent date
Here is a screen grab of one QSO from that ADIF file
If the information is not available Log4OM cannot display it!
Some of the fields that start with <N3FPJ... are program defined fields which do not conform to the ADIF standard so we will not use those fields
vk4tjf
Post by vk4tjf »
cool looks like you nailed down the problem
any way to that I can fix it?
Get N3FPJ to export in a complete and up to date adif format including the QSL, LOTW AND EQSL status and date fields.
Same old same old "Garbage in garbage out" or in this case wrong information results in lack of data
