Since upgrading GridTracker to version 1.18.0530, no more log entries are received by Log4OM. I did not change any settings. Log4OM Communicator as well as GridTracker ports are 2236 as they were before. The communicator's activity log is attached. Anybody else having this problem?
73, Markus HB9BRJ
GridTracker V1.18.0530
- CommunicatorLog.png (63.01 KiB) Viewed 8881 times
Re: GridTracker V1.18.0530
Assuming that you have not changed anything in Log4OM and as you say …..
Did you check the GridTracker settings to ensure that not only is the port number correct but also the IP address and that the 'Enable' button is checked?
I would think that you either had a bad download and/or install of Gridtracker or a setting has changed in GridTracker.Since upgrading GridTracker to version 1.18.0530, no more log entries are received by Log4OM
Have you had a windows update that might affect the defender software and cause it to block the port?
I've got the same problem. I uninstalled 1.18.0530 and reinstalled V 1.18.0513 and it works fine. I'm running Win 10 pro 32 bit.
cheers, Norman, VK6GOM
This is a problem with GridTracker, Stephen N0TTL has promised to fix it today
Download the update https://tagloomis.com/downloads/ and it should be fixed
Please report results here
Re: GridTracker V1.18.0604
Yes, logging is working again!
73, Markus HB9BRJ
73, Markus HB9BRJ
