Missing country on some qso v1.32.
F1NQP
Post by F1NQP »
Hello.
In the "COUNTRY" column, at times, the country is not displayed while the LOCATOR of my correspondent is well informed. Do you have an idea ?
73 to all.
Screenshoot here:
http://www.f1nqp.fr/Capture/Log4OM_problem.png
Re: Missing country on some qso v1.32.
JTalert or wsjt did not pass the country to Log4om, ask them why
F1NQP
Post by F1NQP »
I do not use Jtalert but only JTDX. It's possible, I'll see on this side.
Thank you 73 G4POP
Check the JTDX log
HB9BRJ
Post by HB9BRJ »
Using WSJT-X and GridTracker. Same problem here since I started using Log4OM's communicator. In my opinion, country info is not part of the log entries forwarded to Log4OM. Rather I would expect Log4OM to populate the "country" field in the same way as when importing an ADIF file.
73, Markus HB9BRJ
F1NQP
Post by F1NQP »
Hello.
I just updated LOG4OM.
I checked the ADIF file of JTDX and it is OK.
If I import into LOG4OM the ADIF file from JTDX again, I risk duplicates?
Of 3540 entries, I have about 200 who do not have the country.
Thank you in advance for the answer and good day to all. 73
Why not use the QSO Manager to update the country names
F1NQP
Post by F1NQP »
I did not know there was a possibility by the manager. I try now. Thank you.
Am using always the latest Log4OM version also the latest JTDX and JTAlert. I have found only one
contact without a Country entry an that is D1WW which has no DXCC status .... On my side all is fine.
F1NQP
Post by F1NQP »
it's good it worked.
All the countries are now informed, and I had duplicates.
Thanks for the tip Terry.
73 and good traffic.
F1NQP Jean-Jacques
