LOTW Download
LOTW Download
Hi all, im sure this has been covered somewhere before I have searched and found very little to help me, I have been playing with this for a month trying to get the LOTW to download, upload works fine, but when I hit download all I get is the following... Thanks for any help... Art
Re: LOTW Download
Hi Art,
did you have all correct in the LotW setting in Options/External Logs ?
Station ID must be set and the LotW Password must be the password
that you use for login to the LotW website. The private pass must be
set if you have a password for your certificate.
73´s, Juergen
73´s, Juergen
Re: LOTW Download
Password must not contain special characters like
+×÷=/_€£¥₩!@#$%^&*()-'":;,?`~\|<>{}[]♧
Re: LOTW Download
Thanks for the quick responce, no special characters in the password, and here is the way I have it set up
Re: LOTW Download
Providing your user name and password are the same ones that you use to logon to the ARRL LOTW website and no special characters or spaces are included it should work fine
It also helps if you state what version of Log4om you are using so that we can test with that version!!!
Re: LOTW Download
ok, ill check the version when i get home tonight, but im almost 100% its up to date as well as TQSL.. I work today 9am to 9pm... so we can revisit this late tonight or in the morning... Thanks Again... Art
Re: LOTW Download
The download does not involve Tqsl
Tqsl is only used for upload and you already stated that uploading was fine?
Re: LOTW Download
using version 1.34.0, changed my password again, all letters no numbers still no luck, dont have too much time to fool with it this morning, have to get ready for work, will play with it tonight... thanks for every ones help... Art
Re: LOTW Download
Update to version 1.35 please as the LOTW changes were resolved by this latest release
Re: LOTW Download
downloaded the new version 1.35.0 still doing the same thing...Grrrrrr
