Call sign/country database - Resolved
EI2GLB
Post by EI2GLB »
Hi All
One that needs updating,
Alain, F6BFH will be active from the following Colombian islands between February 5-15, 2013:
February 5-8 from San-Andres NA-033 as HK0/F6BFH.
February 8-11 from Providencia NA-049 as HK0/F6BFH.
February 13-15 from Tierra Bomba SA-040 with HK1/HK3JJH.
When I logged him it defaulted to France and not San-Andres HK0A
Trevor
EI2GLB
Re: Call sign/country database
EI2GLB wrote:Hi All
The call should be entered as he signs on air HK0/F6BFH and then you will get the correct result - Just checked and it works perfectly
Quote from DX World - Note the prefixes
His home call is F6BFH and if you enter that you will only get his home QTH which is France
EI2GLB
Post by EI2GLB »
Well it doesn't work for me, I updated my country and SCL Databases yesterday ??
See the attached image
Are you sure that you entered HK zero and not HKO?
I just tried again and it is 100% accurate because the call is in the SCL
Are you sure that in options/settings 1/ Lookup external sources that you have everything ticked?
EI2GLB
Post by EI2GLB »
I am not going to answer the Zero or O question as I am sure you meant that as a joke :?
Have a look at my settings and see is everything as it should be,
Please go to help about and let me know what version of Log4OM you have installed and the dates of the SCL file
PS. I am not doubting that you downloaded the SCL yesterday I just want to be sure there is not a problem with the download.
EI2GLB
Post by EI2GLB »
Hi Terry
I reloaded the country and SCL files and all seems ok now,
I guess I should have tried that earlier.
Thanks for all the help.
Trevor
EI2GLB
