Hi All
One that needs updating,
Alain, F6BFH will be active from the following Colombian islands between February 5-15, 2013:
February 5-8 from San-Andres NA-033 as HK0/F6BFH.
February 8-11 from Providencia NA-049 as HK0/F6BFH.
February 13-15 from Tierra Bomba SA-040 with HK1/HK3JJH.
When I logged him it defaulted to France and not San-Andres HK0A
Trevor
EI2GLB
Call sign/country database - Resolved
Re: Call sign/country database
The call should be entered as he signs on air HK0/F6BFH and then you will get the correct result - Just checked and it works perfectlyEI2GLB wrote:Hi All
Quote from DX World - Note the prefixes
His home call is F6BFH and if you enter that you will only get his home QTH which is France
Well it doesn't work for me, I updated my country and SCL Databases yesterday ??
See the attached image
- hk0.JPG (86.31 KiB) Viewed 9558 times
Are you sure that you entered HK zero and not HKO?
I just tried again and it is 100% accurate because the call is in the SCL
Are you sure that in options/settings 1/ Lookup external sources that you have everything ticked?
- Untitled.jpg (130.4 KiB) Viewed 9556 times
I am not going to answer the Zero or O question as I am sure you meant that as a joke
Have a look at my settings and see is everything as it should be,
- hk2.JPG (83.65 KiB) Viewed 9553 times
Please go to help about and let me know what version of Log4OM you have installed and the dates of the SCL file
PS. I am not doubting that you downloaded the SCL yesterday I just want to be sure there is not a problem with the download.
Hi Terry
I reloaded the country and SCL files and all seems ok now,
I guess I should have tried that earlier.
Thanks for all the help.
Trevor
EI2GLB
Trevor
EI2GLB
