Unable to download logs from eqsl - 404 error
g4gou
Post by g4gou »
I am able to upload logs to EQSL but today I am longer able to download qsl information.
In the window the transfer starts off normally:
Begin ADIF generation request
Contacting EQSL website
ADIF request accepted
Downloading ADIF document
Contacting EQSL website (download information)
Receive log error: The remote server returned an error (404) Not Found
The log file shows:
2019-10-22 13:34:51.3096 INFO: EqslManagement: Begin receive log (from last download)
2019-10-22 13:34:52.2315 ERROR: *** EqslManagement: Receive log error ******* [Function: #=qPXN8FvAz43$1oUDJJdUgNChJDbJJKzSq$kM6TNTiaBo=] System.Net.WebException: The remote server returned an error: (404) Not Found.
at System.Net.HttpWebRequest.GetResponse()
at LogOM.BL.EqslManagement.#=qPXN8FvAz43$1oUDJJdUgNChJDbJJKzSq$kM6TNTiaBo=(Object #=q91vJrJfjTUC0azROO4QgZQ==, DoWorkEventArgs #=qTXT5V1kCqBYTEapbHP53HA==)
2019-10-22 13:35:02.8803 INFO: EqslManagement: Begin receive log (from last download)
2019-10-22 13:35:03.3334 ERROR: *** EqslManagement: Receive log error ******* [Function: #=qPXN8FvAz43$1oUDJJdUgNChJDbJJKzSq$kM6TNTiaBo=] System.Net.WebException: The remote server returned an error: (404) Not Found.
There was mention on the EQSL website about a migration and issues with https - is this the issue maybe?
Up until today, I have not had any issues.
73 de Mike G4GOU/EA7KIP
Re: Unable to download logs from eqsl - 404 error
Sounds like the EQSL external software portal is not available, perhaps maintenance or similar
Please always include the Log4om version number in posts
G4DZU
Post by G4DZU »
I am getting the same problem with eQSL, it worked perfectly till today.
Log4OM V1.39.0.0 uploads to eQSL, but refuses to download any replies and gives an error as per the attached file.
Hopefully I've done something stupid, but been trying to rectify this all day
73s
Doug
G4DZU
EC1DQ
Post by EC1DQ »
Hi all...
it seems like eqsl changed the download server, but #1 I don't know the name of the new server and #2, even knowing the name of the server, I don't know where to change it in the LOG4OM.
Hope it helps. As soon as I have more feedback, I will forwarded it to the group
All resource links are user reachable, nothing is hardcoded except code...
So, until actual sources doesn't change their protocols, all URL's are user reachable.
In V1, data is in the application folder (where .exe resides, in program files (x86)\IW3HMH\Log4OM folder, inside an XML called: LogOMUI.exe.config
In V2 all those info's will be stored in a good old .INI file in the application settings folder (in the roaming folder of your windows PC, you can find that - even in V1 - from HELP MENU -> OPEN SETTINGS FOLDER
By the way, we're already on HTTPS in Log4OM 1.39 on all resources that supports that.
Actual URL is correct (as per their specifications here http://www.eqsl.cc/qslcard/ImportADIF.txt) and points to: https://www.eqsl.cc/qslcard/ImportADIF.txt
(they stated it's HTTP but it works in HTTPS too, and we're using that)
By the way, this URL is now reachable
g4gou
Post by g4gou »
I looked at the config file and agree, I can reach all the URL's. (Version 1.39)
I tried changing them to http as this was mentioned in the post on the eqsl site about the migration of their servers, this had no effect and I still get the same error as reported by myself and DougG4DZU
It looks like the ADIF file is downloaded ok, but the issue appears to happen when downloading the inbox, going to the website https://www.eqsl.cc/qslcard/DownloadInBox.cfm
I see the following notes:
NOTE: October 22, 2019 the folder structure changed. Look at the hyperlink for the location of the file if retrieving this via an external program ........
Ok, got it... checking
Expect a new release soon.
SP2L
Post by SP2L »
Greetings.
Surprisingly, just while ago I downloaded eQSL without smalest glitch, Hi!
Best regards
Best regards.
Tom - SP2L
https://www.sp2l.eu
GM7GAX
Post by GM7GAX »
As above, working here now
