upload tolotw
KA5MWB
upload tolotw
Post by KA5MWB »
Hi YOU ALL
i have new window 10 computer i can not upload to lotw it said adif file not found on path i can uoload to lotw in admin
it will not upload to lotw in automatic log40 is the great program been using for years
i do not no the in and out of computer need help
thanks
Re: upload tolotw
Log4om version is what?
TQSL version is what?
KA5MWB
Re: upload tolotw
Post by KA5MWB »
i am run 1.40.0 and 2.5.1 tqsl
Re: upload tolotw
I have asked one of our testers in contact you
w6trh
Re: upload tolotw
Post by w6trh »
I hope the solution to this will get posted. I was running log4om 1.40 with tqsl 2.4.7 and was uploading with no problem. I upgraded to tqsl 2.5.1 and it refused to upload running as an administrator. I downgraded back to tqsl 2.4.7, and log4om started working fine again when uploading new QSOs.
Tom
W6TRH
Re: upload tolotw
w6trh wrote: 24 Nov 2019, 07:18 I hope the solution to this will get posted. I was running log4om 1.40 with tqsl 2.4.7 and was uploading with no problem. I upgraded to tqsl 2.5.1 and it refused to upload running as an administrator. I downgraded back to tqsl 2.4.7, and log4om started working fine again when uploading new QSOs.
Tom
W6TRH
Seems the issue is with TQSL 2.5.1, have you asked LOTW about this?
KA5MWB
Re: upload tolotw
Post by KA5MWB »
hi
i upload to tqsl v2.4.7 it upload in adim ok but it did not upload with out adim
signa and upload failed adif file not found on path
upload lotw.txt
(250 Bytes) Downloaded 449 times
upload lotw.txt
(250 Bytes) Downloaded 437 times
upload lotw.txt
(250 Bytes) Downloaded 451 times
Re: upload tolotw
Post a screenshot of the Log4om options/external logs tab please
KA5MWB
Re: upload tolotw
Post by KA5MWB »
S4021058 (2) - Copy - Shortcut ().zip
(627 Bytes) Downloaded 715 times
KA5MWB
Re: upload tolotw
Post by KA5MWB »
how do you Post a screenshot of the Log4om options/external logs?
