Hi YOU ALL
i have new window 10 computer i can not upload to lotw it said adif file not found on path i can uoload to lotw in admin
it will not upload to lotw in automatic log40 is the great program been using for years
i do not no the in and out of computer need help
thanks
upload tolotw
Re: upload tolotw
i am run 1.40.0 and 2.5.1 tqsl
Re: upload tolotw
I hope the solution to this will get posted. I was running log4om 1.40 with tqsl 2.4.7 and was uploading with no problem. I upgraded to tqsl 2.5.1 and it refused to upload running as an administrator. I downgraded back to tqsl 2.4.7, and log4om started working fine again when uploading new QSOs.
Tom
W6TRH
Tom
W6TRH
Re: upload tolotw
Seems the issue is with TQSL 2.5.1, have you asked LOTW about this?w6trh wrote: 24 Nov 2019, 07:18 I hope the solution to this will get posted. I was running log4om 1.40 with tqsl 2.4.7 and was uploading with no problem. I upgraded to tqsl 2.5.1 and it refused to upload running as an administrator. I downgraded back to tqsl 2.4.7, and log4om started working fine again when uploading new QSOs.
Tom
W6TRH
Re: upload tolotw
hi
i upload to tqsl v2.4.7 it upload in adim ok but it did not upload with out adim
signa and upload failed adif file not found on path
upload lotw.txt
- (250 Bytes) Downloaded 448 times
upload lotw.txt
- (250 Bytes) Downloaded 436 times
upload lotw.txt
- (250 Bytes) Downloaded 450 times
Re: upload tolotw
- S4021058 (2) - Copy - Shortcut ().zip
- (627 Bytes) Downloaded 713 times
Re: upload tolotw
how do you Post a screenshot of the Log4om options/external logs?
