Hi
any help to configure ic 7300
Omniring or hamlib?
Ci-V or USB?
Thank you
v2 & ic7300
v2 & ic7300
73 Mauro
iv3hax
io3a
ea8/iv3hax
iv3hax
io3a
ea8/iv3hax
Re: v2 & ic7300
On my IC-7300, Omnirig & USB work fine.
Steve, N4IAG
Steve, N4IAG
Re: v2 & ic7300
HI Steve
what you setting in the 7300 radio config ?
Any other Software work well via usb 115000 and vspe
Log4om all time in TX
73 Mauro
iv3hax
io3a
ea8/iv3hax
iv3hax
io3a
ea8/iv3hax
Re: v2 & ic7300
Mauro, this is what my settings look like. Of course your port may be different.
Edited to add: I’m not sharing the comm port or using port-splitting software.
- setttings.jpg (25.74 KiB) Viewed 3840 times
Re: v2 & ic7300
Same here.N4IAG wrote: 21 Jan 2020, 17:30 Edited to add: I’m not sharing the comm port or using port-splitting software.
If using the IC-7300 for data modes, like FT8, suggest you use the IC-7300(Data) ini file for Rig type. It puts the radio in USB-D mode, which is better.
I also have RTS and DTR set to low, and the Poll int. to 100ms.
