Fldigi qso's not auto uploading
KE4BCN
Post by KE4BCN »
When a qso from Fldigi is added to Log4OM the auto update to qrz, eqsl and clublog does not work. It works fine with JtAlert.
F5SIB
Re: Fldigi qso's not auto uploading
Post by F5SIB »
Check options below Adif adress line ,
Thierry
KE4BCN
Post by KE4BCN »
I checked the box as instructed but it will not stay checked when save/exit. Next time I enter it's unchecked.
KE4BCN wrote: 24 Jan 2020, 02:27 I checked the box as instructed but it will not stay checked when save/exit. Next time I enter it's unchecked.
Ross,
I don't think you need to check the box in Configuration/ADIF Functions.
Did you follow in detail the Auto Upload setup as noted in the Users Guide starting on Page 68?
You have to be sure of passwords that don't have restricted characters, etc..
If you have the Auto Upload properly configured once a QSO gets saved in your log it will automatically be updated to the respective location within a few minutes. A delay is automatically configured in V2 to allow the OM to modify or cancel the QSO just in case ... before it gets Auto Uploaded.
When I have Auto Upload configured I will go and look at each of the locations I upload to from the QSL Manager window and select Clublog, HamQTH, etc., etc.. You can see the Q's there that should then have a green highlighted YES with the sent date in a nearby column.
I'll do that review when I'm done operating for the day or at least at some interval after I've stopped operating before I shut down my station.
You can also look at: Help/Open Log File and see all your activity with V2. You can locate where you attempted an Auto Upload and V2 will capture all sorts of information that will be helpful. Will even advise (as I recall) if there is an invalid password being used.
Give that a go and let us know.
Thanks for using Log4OM2.
HB9VQQ
Post by HB9VQQ »
Flex 6600 - Spiderbeam
All those fields are saved when you create the rule. You can monitor different files and have different needs for each of them
If you need to change a rule, adding new parameters, remove the rule and recreate it with the parameters you need.
This flag is NOT working for each ADIF imported file but only on those that explicitly you marked with during the creation.
If that is not working this way please return to us with a report so we can check it
HB9VQQ
Post by HB9VQQ »
Works as expexcted for me. Logging QSO in FlDigi will upload the QSO to external services automatically.
Roland
KE4BCN
Post by KE4BCN »
Thank you for all the help finally got it working.
