LOG4OM V1 adif to V2
IW3RAB
Post by IW3RAB »
I try to import my LOG4OM V1 adif in V2 but have a couple of doubts.
Referring to importlog.txt I can see the renaming of Macedonia to North Macedonia
That can be good, eg.:
from: https://en.wikipedia.org/wiki/Macedonia_naming_dispute
"official renaming of Macedonia to North Macedonia in February 2019"
ARRL DXCC LIST
CURRENT ENTITIES
March 2019 Edition is "North Macedonia"
bigcty-20190212 is "Macedonia"
bigcty-20190319 is "North Macedonia"
But:
(Released ADIF Version 3.1.0, updated 2019/05/21)
is "Macedonia"
The second of doubts refer to Asian to European Russian conversion (DXCC has changed from 15 to 54) for some records of old QSO (2010/2013).
For some calls can be right but for other I am in trouble.
All the calls on QRZ.com and hamqth.com are marked as 15 Asiatic.
The results from qrzcq.com are different for some.
What do you suggest me ?
73 Sandro IW3RAB
Sandro IW3RAB
Re: LOG4OM V1 adif to V2
Either turn of the checking during import or edit the QSO's after imported
Perfect accuracy is something we strive for but which is almost impossible to achieve sometimes human intervention is required.
CIao Sandro
we use as source the archives in Clublog.
Can you check some of the calls of your list in the clublog callsign checker, with correct qso date?
About Macedonia and North Macedonia, you're right. It seems ADIF committee is sleeping on it... we moved according to official rules but, yes, it was a choice.
IW3RAB
Post by IW3RAB »
Hi Lele
Good idea and solution.
I register to Club Log and verify some of the calls.
Club Log.PNG (6.74 KiB) Viewed 2944 times
This is an exaple, with call in europe but is in AS
Sandro IW3RAB
