Alert Managment.
Re: Alert Managment.
W7DRM wrote: 24 Jan 2020, 03:18 Here is a workaround. Eliminate the Origin criteria. I did and it is working for me. Also, you could filter your spots by NA spotters either at the Cluster level (preferred) or on the Cluster Filter tab and end up with the same results as two alert criteria.
It appears filtering it on the cluster tab will not work. Because when I do I get audible alerts for non NA spots I cant see.
NN7D
Post by NN7D »
Rich,
Thanks for reporting. I've replicated the issue and will add it to the fix list.
Doug - W7DRM
You can have multiple cluster screen.
Each screen is customizable on specific needs. On the other side, alerts works on raw data provided by cluster. If not, you may miss an alert because you filtered out a specific beam direction or a specific situation in one of the clusters.
So, if you set an alert, this will triggers without regards of filters placed on cluster(s) visualization.
