always no tx fldigi & log4om
HB9VQQ
Re: always no tx fldigi & log4om
Post by HB9VQQ »
Bonsoir Eric,
that's the Magic built in Log4OM :-)
Roland
Flex 6600 - Spiderbeam
F1SMV
Post by F1SMV »
gm Terry
ah may be where ? because morning i check again setup in log4om and i cant see anywhere xml rpc ..only in flidigi i can see
73 Eric
F1SMV
Post by F1SMV »
Roland
i check , its ok i have same that you..in TCP-IP sessions
73 Eric
F1SMV wrote: 29 Jan 2020, 07:07 gm Terry
73 Eric
Not sure what version of FLdigi your using but it should be 4.1.08 or later and you need the I/O config tab not rig control
IK0TIX
Post by IK0TIX »
sorry if I insist, but I think that Eric's problem continues to be the com port is not split.
N8VBvcom does not do this but only virtual com.
The original problem was no TX
Max IK0TIX
F1SMV
Post by F1SMV »
Bonjour Terry
i use fldigi 4.1.09.12 version ...
Mark
do you think i must back on vspe ? ..but i try without more success..
this morning i test in same cfg my "old version" of log4om (version 1), work ! tx is ok
for your info i put my setup , i see tcp port arent the same does i must change in misc\tcpip sessions ?
73 Eric
IK0TIX
Post by IK0TIX »
Indeed Eric.
I don't remember if in V1 I used the com splitter port.
Certainly V2 does not command TX via TCP / IP, or at least it does not work for me.
This is why I insist on splitting the com port.
@ Terry: Can Log4OM V2 send the rig in TX via TCP/IP?
Max IK0TIX
IK0TIX wrote: 30 Jan 2020, 09:05 Indeed Eric.
No and neither did V1, PTT is triggered within FLDigi
SQ5TDZ
Post by SQ5TDZ »
GM
in earlier versions of fldigi the connection of log40m v1 with fldigi worked without a problem, now these versions of fldigi do not want to work even with other software, as separate software works without a problem. this is my observation
Regards
Andrew.....SQ5TDZ
s51cn
Post by s51cn »
HI Eric
FLdigi 4.1.09 has new look of Configuration window and look on picture where you find TCP-ip session.
It is working for me.
73 Bojan S51CN
